Manage memory in STM32F407
anhhuy0701
Posted on June 02, 2014 at 06:49
Hello everyone
today I have one problem with my manage memory
I run freeRTOS in stm32f4 board (Cortex M4), I create one task. This task execute regular expression program (source code for regexp from: http://www.arglist.com/regex/).
because program recusive many times, so in RTOS, I config max heap is 112Kb, but it is not enough. When I build Keil print statement:
.\build\zrfid.axf: Error: L6406E: No space in execution regions with .ANY selector matching heap_4.o(.bss).
.\build\zrfid.axf: Error: L6407E: Sections of aggregate size 0x1c000 bytes could not fit into .ANY selector(s).
can anyone help me that problem??
Thank and regard!
Posted on June 02, 2014 at 07:32
Ok, but what have you defined for the memory under the ''Target'' tab of the Options?
anhhuy0701
Posted on June 03, 2014 at 01:07
already clive1
