Latest update date in literature selector missing
Uwe Bonnes
Chief
Posted on February 02, 2017 at 11:51
in the
http://www.st.com/content/st_com/en/support/resources/resource-selector.html?querycriteria=productId=FM141$$resourceCategory=technical_literature$$resourceType=programming_manual
the latest update field is empty. With the lastest update date given, a search for what has changed would be easy. Without that date, one has to navigate to the product and compare the document revision there with the the local revision.
Is there another way to see what documents changed?
Uwe Bonnes
Chief
Posted on May 29, 2017 at 12:11
Sorting by date now works as expected. Thanks!
Any thoughts about adding the datasheets to the resources?
6 REPLIES 6
Uwe Bonnes
Chief
Posted on April 11, 2017 at 19:33
the column 'Latest Update'  now shows  the dates. Thanks! But dates are sorted in alphabetical order, not calendaric order. So
'Apr 4, 2016' comes before 'Feb. 10, 2017'. Please rethink sorting order!
Cheers!
Posted on May 05, 2017 at 11:22
Sorting is still broken.
Posted on May 05, 2017 at 14:09
Bonnes.Uwe
We have been working on it. It's now ready and testedon our pre-production server and will be ported to the production environment by the end of next week.
Posted on May 06, 2017 at 13:47
Thanks for working on that subject!
Are the data and errata sheets listed somehow in the same way? If not, I would suggest to list the under hardware resources as well.
Posted on May 06, 2017 at 13:57
'to list the under' -> 'to list them under'
Uwe Bonnes
Chief
