L6218E Error
kqian
Posted on January 21, 2014 at 19:54
The original post was too long to process during our migration. Please click on the attachment to read the original post.
Posted on January 21, 2014 at 20:54
One might presume you have a multi-target project, and you haven't enabled the files you need in the context of your current target.
kqian
Posted on January 21, 2014 at 21:55
Hey Clive
I changed target after coding.
''and you haven't enabled the files you need in the context of your current target.''
What do you mean enable the files for current target?
Posted on January 22, 2014 at 04:05
Ok, so you're supposedly building for a STM322xG-EVAL board, a board with STM32F2xx related files, none are shown in your tree.
Goto Project -> Manage -> Components, Environments, Books
Select the ''Project Target'' you're attempting to build, and then navigate the ''Groups'', and manage the ''Files''
Now unless there is some relationship set up, it's not going to build a whole bunch of files and consequentially it's going to fall over and die during the link phase.
You might want to consider what board you've selected as a target.
