Is there an SRAM example code module around to drive static SRAM in the L4R5 CPU?
Dan Mackie
Now that there is an STM32 cpu chip with larger on-board memory, I would like to make use of it, but I have not found any working examples in that line. Reading the SRAM module in the HAL driver section is not much help.
waclawek.jan
Isn't it just simply matter of declaring variables into it?
Dan Mackie
Hi Jan,
Perhaps it is - nothing like a test to prove it. Seems to me in the past you had to have application code that managed the process, but a cursory inspection of my past code has not yielded an example as yet.
Thanks,
Dan
