is it available to get 9MHZ PWM from STM32F334
‎2017-10-21 1:58 AM
Hi ST,
my purpose is to use STM32F334 to output 9MHZ PWM ,and need to adjust the pulse width each period by the burst DMA of the chip, is it available ? thanks
‎2017-10-22 5:48 AM
AN4776 Chapter 5
If you don't want to adjust both period and duty cycle, but only duty cycle, you don't need a DMA 'burst', just a plain DMA write to given TIMx_CCRy register.
9MHz sounds a bit high frequency though, did you intend to use the HRTIM?
‎2017-10-22 6:07 AM
This is ST's forum, but most of the support comes from users here.
Seems rather high to need modulating on a cycle-by-cycle basis, have you considered a CPLD?
DMA would just write a new CCRx value on each Update, but I think 9 MHz would cause some considerable contention, and your buffer would need to be rather large to stop the interrupt loading from saturating the processor.
‎2017-10-22 6:13 AM
Hi JW, thank you for your reply.
Yes , use the HRTIM, the purpose is to output SPWM at 9MHZ carrier wave , just want to confirm if STM32F334 is fast enough to adjust the duty cycle at each period(9MHZ) by DMA. I checked the table 83 at Referece manual 'RM0364',0-100% duty cycle is impossible , but it is also OK to get 20%-80% for my application;
It would be apprecated if there is SPWM sample with HRTIM
Thanks,
JL
‎2017-10-22 7:46 AM
Hi Clive,
thank you for your reply,
use HRTIM with DAM to update the duty cycle instead of interrupt method. The duty resulotion is up to 217ps.
But , how many clock cycles to update the set of the registers by each DMA transfer,I can't get the clear informtion from ST datasheet , from
the table 83 of Referece manual 'RM0364' , I guess it is 3 cycles at 72MHZ .
I have to wait ST guy's answer.
Thanks,
J L
‎2017-10-22 8:47 AM
I think 9 MHz should be doable, but at 72 MHz that would be 8 cycles, so adjustment of duty is going to be rather coarse.
0 is OFF (0%), 8 is ON (100%), 1 is 12.5%
‎2017-10-22 10:19 AM
It depends on how the output is being used. DAC for precise analog output if possible.
Then if 9 MHz, you would have 10 steps at 90MHz and 20 steps at 180MHz raw.
Of course, you can use DMA looping through 2,4,8,16 duty cycles to implement dithering if allowed.
==> Dithering example: If 10 steps, by changing every timer period the duty cycle between both 30 and 40% value, you get averaged 35% with half timer period modulation.
With a more detailed knowledge of the HW, the architecture choice can be refined.
‎2017-10-22 3:33 PM
the table 83 of Referece manual ''RM0364'' , I guess it is 3 cycles at 72MHZ
More like 6 AHB + 2 APB cycles, if there's no collision with other masters on the buses and no other DMA channel active - this might be a showstopper.
I know AN2548 is for 'F1 and 'L1, but the DMA in 'F3 appears to be of the same design.
I'd recommend you to write a simple test application, perhaps on a Disco or Nucleo, before commencing with design. Using external modulator as Clive suggested above is always a sure bet of course.
‎2017-10-22 8:52 PM
Thanks JW,
How many latency cycles at HRTIM DMA on STM32F334 , hope to get the ST official answer soon ...
