Interrupt priority grouping on stm32f1xx series
Options
‎2015-04-30 3:12 AM
Posted on April 30, 2015 at 12:12
In programming manual (PM0056) in the description of ''Application interrupt and reset control register (SCB_AIRCR)'' two things are written:
1) Bits 10,9 and 8 defines PRIGROUP - they determine the split of group priority from subpriority. Later, in the table 45, all correct values of these bits are listed and they are: 0b011, 0b100, 0b101, 0b110 and 0b111. 2) Reset value of this register is said to be 0xFA05 0000 - so after reset PRIGROUP bits are all zero. And that value is not listed in the table, so it must be incorrect. Please tell me, am I correct? And if I am, how exactly will subpriorities work after reset? #stm32 #interrupts #preemption
Labels:
- Labels:
Interrupt
2 REPLIES 2
Options
‎2015-05-14 9:32 AM
Posted on May 14, 2015 at 18:32
Hi Roman,
After reset, the behavior will be the same as when 4 bits are used for group priority and 0 bit for subpriority. It means the equivalent of PRIGROUP = 011.Best Regards-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
Options
‎2015-05-15 1:55 AM
Posted on May 15, 2015 at 10:55
Thanks, Myala!
