Increase SPI Frequency on STM32F4 Disc
‎2015-05-17 8:29 AM
Hi there , I use the SPI3 unit on my STM32F4 Discovery board to control a TFT. I want the images to load faster and as a result I need to increase the SPI3 clock/frequency. Currently this line of code clocks the unit:
RCC->APB1ENR |= RCC_APB1Periph_SPI3;Any idea how can I get to 1.5 or 2 MHz.Thank you- Mark as New
‎2015-05-17 8:49 AM
Well that seems relatively slow.
Given the way the prescalers work you might have to play with the CPU and AHB/APB clocks to hit specific rates you want. You might have to run the CPU slower than maximal to get the integer divisions you need.Up vote any posts that you find helpful, it shows what's working..
‎2015-05-17 9:11 AM
Hi there, thank you for your quick reply. Actually what I want is faster not slower. As far as I know the STM32F4 Disc runs with 8 Mhz crystal. So is it the AHB or the AHP that can give me the right speed ? it's because the bitmaps are showing slowly on my 128*128 tft
‎2015-05-17 9:57 AM
The STM32F4-DISCO has an 8 MHz external source, and 16 MHz internal one, but those can feed to a PLL/VCO capable of running the CPU at 168 MHz, with the buses at fractions of that.
‎2015-05-17 10:28 AM
So what do you suggest sir ?
I need At least the tft to update with 10fps . How can colck it to be faster ? Thank you- Mark as New
‎2015-05-18 3:26 PM
Which STM32F4? For STM32F429
RCC->APB1ENR |= RCC_APB1Periph_SPI3 Enables the clock to the SPI Bits 3-5 (BR) in SPI_CR1 Set the divisor value of the clock. According to the 429 datasheet SPI3 can communicate at up to 22.5 Mbit/s (SPI1, SPI4, SPI5, and SPI6 up to 45 Mbits/s) assuming you have overdrive on and so running it at 180MHz. So APB1 running at 45MHz/32 = 1.41MHz (BR[2:0] = 100) 45MHz/16 = 2.8MHz (BR[2:0] = 011)
