In STM32F103, CAN data was not sent. Help Me
RSing.12
I received CAN data successfully but when I send CAN data, there was some error shown.
My Code is,
https://drive.google.com/file/d/1g67-LwlqfaCf8QpeAptYLtTEByo_R9nr/view?usp=sharing
Javier1
Principal
Come on man, your code is in a pdf file without any format.
If you want people to help take 1 minute to explain it or to lay it out....
What kind of developing ide are you using , are you using arduino and a bluepill?
Explain your setup a bit, how are you testing it? how do you know its failing? where is that log captured image comming from.?
we dont need to firmware by ourselves, lets talk
RSing.12
I'm using STM32F103 Controller and MCP2551 module.
It's not a blue pill board but it's almost similar.
I'm using Arduino IDE for boot loading the controller.
