iar 5.4::::::: Failed to load flash loader
cloudreaching
Posted on January 04, 2010 at 08:16
3 REPLIES 3
cloudreaching
Posted on May 17, 2011 at 13:36
hi,
i used iar5.4 to debug my application with st-link, but iar always tells me failed to load flash loader. it is a week passed ,i still not solve this problem, how can i deal it? thanks!
best regard!
st3
Have you spoken to IAR support?
jj
Check under Projects>Options that the proper ''debugger'' is selected. (don't believe that my 5.2 ver. of IAR lists ''st-link'')
Are you able to run the debugger - debug any code?
Describe your hardware - are you ''booting'' the MCU correctly?
