i2s want to run my project with stm32nucleo and pcm4201 mic ic... not working PC6= I2S2_MCK
erkan_34_TR_
4 REPLIES 4
What's the question? You don't have clock on I2S2_MCK? And are there clocks on the remaining clock outputs? I'm not going to check your code, but read out the relevant GPIO and SPI/I2S registers and check their content.
erkan_34_TR_
GPIO_InitTypeDefStruct.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_6;
GPIO_InitTypeDefStruct.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitTypeDefStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_InitTypeDefStruct.GPIO_Speed = GPIO_Speed_50MHz;   // GPIO_Low_Speed
GPIO_InitTypeDefStruct.GPIO_OType = GPIO_OType_PP;
    GPIO_AF_SPI2;
GPIO_Init(GPIOC, &GPIO_InitTypeDefStruct);
    RCC_I2SCLKConfig(RCC_I2S2CLKSource_PLLI2S);
    RCC_PLLI2SCmd(ENABLE);
    RCC_GetFlagStatus(RCC_FLAG_PLLI2SRDY);
    while(RCC_GetFlagStatus(RCC_FLAG_PLLI2SRDY) == RESET);
but not out clk signal
erkan_34_TR_
 /* Enable PLL Ready interrupt */
    RCC_ITConfig(RCC_IT_PLLI2SRDY, ENABLE);
    RCC_ClearITPendingBit(RCC_IT_PLLI2SRDY);
I don't use SPL. But why don't you read out the registers content and check them.
Btw. this line is suspicious:
   GPIO_AF_SPI2;
