I would like to use functionalities like sine, cosine etc in my code without using math.h library.
Gautham  Y.T
Please provide me the solution for this.
AvaTar
Lead
Use the math lib, or implement a table-based interpolation yourself.
Consider an integer-based solution.
You did not even mention the MCU you are working with.
Andrew Neil
Why do you want to avoid math.h ?
Have you looked at: https://www.keil.com/pack/doc/CMSIS/DSP/html/group__groupFastMath.html
Did you do any research yourself?
eg, google found this: https://digital.library.unt.edu/ark:/67531/metadc283001/
See also: https://en.wikipedia.org/wiki/CORDIC
