I would like to run an arduino nano sketch on STM 32, Only 4 pins are need to define.... please help me to do this.... The code is working perfectly on my circuit, due to arduino nano memory is less, so i am unable to add more leds (ws2812B). Thank you.
SDamo.1
  Code for Arduino WS2812b-MSGEQ7 Spectrum Analizer.
  https://www.youtube.com/watch?v=mGton_zqrS0
#include <FastLED.h>
#define NUM_LEDS 70
#define COLUMN 7
#define ROWS 10
#define DATA_PIN 6
#define STROBE_PIN 3
#define RESET_PIN 2
#define BRIGHTNESS 100
#define NOISE 35
// Matrix Definition
CRGB leds[NUM_LEDS];
typedef struct ledrgb   //structure containing the parameters relating to a led
 int r;
 int g;
 int b;
 int hue;
 int sat;
 int val;
 int nled;
 boolean active;
} led;
led colors[COLUMN][ROWS]; //matrix containing the progressive number of each single LED
//Global Variables
int left_input[7];  //Audio Input array
int nlevel;   //level index
int delta = 50;  //Value working with my matrix 7x10
int hue_rainbow = 0; //global variable for the rainbow variable hue
int long rainbow_time = 0;
int long time_change = 0;
int effect = 0;
void setup() {
 Serial.begin (9600);
 pinMode (DATA_PIN, OUTPUT);
 pinMode (STROBE_PIN, OUTPUT);
 pinMode (RESET_PIN, OUTPUT);
 int n = 0;
 for (int i = 0; i < COLUMN; i++) {  //number the leds (depends on how they are connected)
  for (int j = 0; j < ROWS; j++) {
   colors[i][j].nled = n;
   n++;
 FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
 FastLED.setBrightness( BRIGHTNESS );
 rainbow_time = millis();
 time_change = millis();
void loop() {
 readMSGEQ7();
 if (millis() - time_change > 12000) {  //code that establishes how often to change effect
  effect++;
  if (effect > 7) {
   effect = 0;
 switch (effect) {
  case 0:
   rainbow_dot();
   full_column();
   updateHSV();
   break;
  case 1:
   if (millis() - rainbow_time > 15) {
    dinamic_rainbow();
   full_column();
   updateHSV();
   break;
  case 2:
    rainbow_column();
   full_column();
   updateHSV();
   break;
  case 3:
    total_color_hsv(255, 255, 255);
   full_column();
   updateHSV();
   break;
  case 4:
    rainbow_dot();
   full_column_dot();;
   updateHSV();
   break;
  case 5:
    dinamic_rainbow();
   full_column_dot();
   updateHSV();
   break;
  case 6:
    rainbow_column();
   full_column_dot();
   updateHSV();
   break;
  case 7:
   total_color_hsv(55, 255, 255);
   full_column_dot();
   updateHSV();
   break;
 delay(30);
/////FUNCTIONS
// Function that reads the 7 bands of the audio input.
void readMSGEQ7(void) {
 digitalWrite(RESET_PIN, HIGH);
 digitalWrite(RESET_PIN, LOW);
 for (int band = 0; band < COLUMN; band++) {
  digitalWrite(STROBE_PIN, LOW);
  delayMicroseconds(30);
  left_input[band] = analogRead(A5) - NOISE; //saves the reading of the audio input.
  digitalWrite(STROBE_PIN, HIGH);
void updateRGB(void) {
   if (colors [i][j].active == 1) {
    leds[colors[i][j].nled] = CRGB(colors[i][j].r, colors[i][j].g, colors[i][j].b);
   } else {
    leds[colors[i][j].nled] = CRGB::Black;
   FastLED.show();
void updateHSV(void) {
   if (colors[i][j].active == 1) {
    leds[colors[i][j].nled] = CHSV(colors[i][j].hue, colors[i][j].sat, colors[i][j].val);
   } else {
 FastLED.show();
void full_column(void) {
 nlevel = 0;
  nlevel = left_input[i] / delta;
   if (j <= nlevel) {
    colors[i][j].active = 1;
   else {
    colors[i][j].active = 0;
  //colors[i][peaks[i]].active=1;
void full_column_dot(void) {
 nlevel = 0;
   if (j == nlevel) {
   else {
void total_color_hsv(int h, int s, int v) {
   colors[i][j].hue = h;
   colors[i][j].sat = s;
   colors[i][j].val = v;
void total_color_rgb(int r, int g, int b) {
   colors[i][j].r = r;
   colors[i][j].g = g;
   colors[i][j].b = b;
void rainbow_column(void) {
 int n = 36;
   colors[i][j].hue = n;
   colors[i][j].sat = 230;
   colors[i][j].val = 240;
  n += 36;
void rainbow_dot(void) {
 int n = 36;
   n += 5;
void dinamic_rainbow(void) {
   colors[i][j].hue = hue_rainbow;
 hue_rainbow++;
4 REPLIES 4
Piranha
Chief II
For a start replace most of those int variables (including in struct ledrgb) with uint8_t. On 8-bit AVR you will gain everything - RAM, flash and execution speed.
prain
Senior III
You may want to take a look ​at stm32duino project. It's an Arduino port for stm32 MCUs. The popular blue pill board is supported by stm32duino.
SDamo.1
I am already having a blue pill and ST link hardware,
I just change the pin number and compiled like .....
#include <WS2812B.h>
#define NUM_LEDS 70
#define COLUMN 7
#define ROWS 10
#define DATA_PIN PB8
#define STROBE_PIN PB3
#define RESET_PIN PB4
#define NOISE 35
this is the message after compiling ...
I am not an experienced programmer, and fresh with STM32,
exit status 1
no matching function for call to 'CFastLED::addLeds(CRGB [70], int)'
SDamo.1
the sketch in the example library is working on the blue-pill
