I would like to run an arduino nano sketch on STM 32, Only 4 pins are need to define.... please help me to do this.... The code is working perfectly on my circuit, due to arduino nano memory is less, so i am unable to add more leds (ws2812B).
Thank you.
‎2020-08-01 10:34 AM
Code for Arduino WS2812b-MSGEQ7 Spectrum Analizer.
https://www.youtube.com/watch?v=mGton_zqrS0
#include <FastLED.h>
#define NUM_LEDS 70
#define COLUMN 7
#define ROWS 10
#define DATA_PIN 6
#define STROBE_PIN 3
#define RESET_PIN 2
#define BRIGHTNESS 100
#define NOISE 35
// Matrix Definition
CRGB leds[NUM_LEDS];
typedef struct ledrgb //structure containing the parameters relating to a led
int r;
int g;
int b;
int hue;
int sat;
int val;
int nled;
boolean active;
} led;
led colors[COLUMN][ROWS]; //matrix containing the progressive number of each single LED
//Global Variables
int left_input[7]; //Audio Input array
int nlevel; //level index
int delta = 50; //Value working with my matrix 7x10
int hue_rainbow = 0; //global variable for the rainbow variable hue
int long rainbow_time = 0;
int long time_change = 0;
int effect = 0;
void setup() {
Serial.begin (9600);
pinMode (DATA_PIN, OUTPUT);
pinMode (STROBE_PIN, OUTPUT);
pinMode (RESET_PIN, OUTPUT);
int n = 0;
for (int i = 0; i < COLUMN; i++) { //number the leds (depends on how they are connected)
for (int j = 0; j < ROWS; j++) {
colors[i][j].nled = n;
n++;
FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( BRIGHTNESS );
rainbow_time = millis();
time_change = millis();
void loop() {
readMSGEQ7();
if (millis() - time_change > 12000) { //code that establishes how often to change effect
effect++;
if (effect > 7) {
effect = 0;
switch (effect) {
case 0:
rainbow_dot();
full_column();
updateHSV();
break;
case 1:
if (millis() - rainbow_time > 15) {
dinamic_rainbow();
full_column();
updateHSV();
break;
case 2:
rainbow_column();
full_column();
updateHSV();
break;
case 3:
total_color_hsv(255, 255, 255);
full_column();
updateHSV();
break;
case 4:
rainbow_dot();
full_column_dot();;
updateHSV();
break;
case 5:
dinamic_rainbow();
full_column_dot();
updateHSV();
break;
case 6:
rainbow_column();
full_column_dot();
updateHSV();
break;
case 7:
total_color_hsv(55, 255, 255);
full_column_dot();
updateHSV();
break;
delay(30);
/////FUNCTIONS
// Function that reads the 7 bands of the audio input.
void readMSGEQ7(void) {
digitalWrite(RESET_PIN, HIGH);
digitalWrite(RESET_PIN, LOW);
for (int band = 0; band < COLUMN; band++) {
digitalWrite(STROBE_PIN, LOW);
delayMicroseconds(30);
left_input[band] = analogRead(A5) - NOISE; //saves the reading of the audio input.
digitalWrite(STROBE_PIN, HIGH);
void updateRGB(void) {
if (colors [i][j].active == 1) {
leds[colors[i][j].nled] = CRGB(colors[i][j].r, colors[i][j].g, colors[i][j].b);
} else {
leds[colors[i][j].nled] = CRGB::Black;
FastLED.show();
void updateHSV(void) {
if (colors[i][j].active == 1) {
leds[colors[i][j].nled] = CHSV(colors[i][j].hue, colors[i][j].sat, colors[i][j].val);
} else {
FastLED.show();
void full_column(void) {
nlevel = 0;
nlevel = left_input[i] / delta;
if (j <= nlevel) {
colors[i][j].active = 1;
else {
colors[i][j].active = 0;
//colors[i][peaks[i]].active=1;
void full_column_dot(void) {
nlevel = 0;
if (j == nlevel) {
else {
void total_color_hsv(int h, int s, int v) {
colors[i][j].hue = h;
colors[i][j].sat = s;
colors[i][j].val = v;
void total_color_rgb(int r, int g, int b) {
colors[i][j].r = r;
colors[i][j].g = g;
colors[i][j].b = b;
void rainbow_column(void) {
int n = 36;
colors[i][j].hue = n;
colors[i][j].sat = 230;
colors[i][j].val = 240;
n += 36;
void rainbow_dot(void) {
int n = 36;
n += 5;
void dinamic_rainbow(void) {
colors[i][j].hue = hue_rainbow;
hue_rainbow++;
STM32duino
STM32F1 Series
‎2020-08-01 11:45 AM
For a start replace most of those int variables (including in struct ledrgb) with uint8_t. On 8-bit AVR you will gain everything - RAM, flash and execution speed.
‎2020-08-02 12:05 AM
You may want to take a look ​at stm32duino project. It's an Arduino port for stm32 MCUs. The popular blue pill board is supported by stm32duino.
‎2020-08-02 3:58 AM
I am already having a blue pill and ST link hardware,
I just change the pin number and compiled like .....
#include <WS2812B.h>
#define NUM_LEDS 70
#define COLUMN 7
#define ROWS 10
#define DATA_PIN PB8
#define STROBE_PIN PB3
#define RESET_PIN PB4
#define NOISE 35
this is the message after compiling ...
I am not an experienced programmer, and fresh with STM32,
exit status 1
no matching function for call to 'CFastLED::addLeds(CRGB [70], int)'
‎2020-08-02 4:00 AM
the sketch in the example library is working on the blue-pill
