I would like to know if there is an evaluation board for STM32F413ZHJ6 that supports ETM and JTAG ..and how JTAG is wired up when supporting ETM ?
Lmyle.11
My understanding is that it is unified, basically you have the SWD + Trace, and the Debug/Trace occurs through that rather than a "JTAG" mode
The Trace Pod is your debugger
10 REPLIES 10
Check the part# Google is giving me nothing helpful. Things which are unique or niche might need to be special ordered.
PDQ Logic has some STM32 Demonstrator Boards
https://www.pdqlogic.com/
Seemed to remember Segger having some too.
Lmyle.11
Thank you for your advice !
Sorry part number : STM32F413ZHJ6 thanks
So a UFBGA-144
I suspect you're going to have to find a proxy
ST doesn't have an EVAL series board for the STM32F413's
Schematics for the STM32F4 EVAL boards, and MCBSTM32F400 should show ETM Trace connectivity
https://www.keil.com/mcbstm32f400/
thanks for your support and fast response !
On the STM32 can you have JTAG and ETM active at the same time ?or would you need to switch? or does only one need to be activated at any one time? Thanks
