I can't rebuild a project successfully.
stm32f4cube - Audio_playback and recorder sample project
I have tried adding program section .rev16_text on flash_placement.xml but it work. Any help will be appreciated.
‎2018-11-10 3:12 PM
‎2018-11-10 4:02 PM
Are you using PC or MAC ?
Which compiler are you using ?
‎2018-11-11 3:34 AM
I am using crossworks for arm v3.7 (windows 8.1 )and gcc compiler.
‎2018-11-11 7:35 PM
did you compile any project successfully ?
I use Visual Studio with GDB extensions, but it cost $150, but works very well, if you start with the cube...
some examples dont have the cube as a starting point, I struggled with those also..
‎2018-11-12 12:56 AM
okay T J but when I compile my main.c, everything is fine.
