HSE Bypass Clock Source w/CubeMX and Nucleo 303ZE fails
Larry Lukis
Posted on March 27, 2017 at 01:42
Possible bug in CubeMX 4.20.0?
Using Nucleo 303ZE board, and Atollic 7.1.1
Build dead simple default project, except in RCC, set High Speed Clock to 'BYPASS Clock Source', and select HSE as input to PLL.
In main.c you'll have this routine:
void SystemClock_Config(void)
/**Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL2;
RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1;
Error_Handler();
,,, etc,
Results in bad return from HAL_RCC_OscConfig() and call to Error_Handler().
If you change this line:
to
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
it runs fine.
Not sure if there is something I don't understand, or if it is possibly a bug in CubeMX. my .ioc file attached.
Jeanne Joly
Senior III
Posted on April 28, 2017 at 09:38
Hi
Lukis.Larry
I would inform you that anew patch
http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-configurators-and-code-generators/stm32cubemx.html
V 4.1is available to fix this issue.
Sorry for any inconvenience this may cause you.
BR. Eric
Nesrine M_O
Lead II
Posted on March 27, 2017 at 12:43
Hi
larry.lukis
Please note that this is a confirmed CubeMX bug whichwill be fixed in a patch to be delivered soon.
Sorry for anyinconvenience it may bring.
-Nesrine-
Jeanne Joly
Senior III
Hi
Lukis.Larry
BR. Eric
