How use Serial Wire Output ?
asrock70
Posted on February 23, 2014 at 10:25
Can you advise
some
example that
would use the
SWO
port
for
output from the
program
in
UART
mode
Ideal
for
STM32F1
and
MDK
-ARM
Posted on February 23, 2014 at 14:48
Make sure to set up the trace mode with the correct processor frequency, and checked options
http://www.keil.com/download/files/labst.pdf
The following allows putchar/printf to function:
#include <
stdio.h
#include <
rt_misc.h
#pragma import(__use_no_semihosting_swi)
struct __FILE { int handle; /* Add whatever you need here */ };
FILE __stdout;
FILE __stdin;
int fputc(int ch, FILE *f)
ITM_SendChar(ch);
return(ch);
int fgetc(FILE *f)
char ch;
ch = 1;
return((int)ch);
int ferror(FILE *f)
/* Your implementation of ferror */
return EOF;
void _ttywrch(int ch)
ITM_SendChar(ch);
void _sys_exit(int return_code)
label: goto label; /* endless loop */
