2020-03-06 11:03 PM
2020-03-07 1:34 AM
There are Getting started with ... series hardware development application notes for each MCU series.
A minimal design should have
Analog applications using ADC/DAC/COMP etc should have a separate Vdda/Vssa supply, otherwise they can be connected to Vdd/Vss.
2020-03-07 12:12 AM
Design the board, by the parts, solder the parts - how does STM32 differ from any other chip?
2020-03-07 1:34 AM
2020-03-07 1:40 AM
Does the factory shipped chip (STM32 series) contain a hardcoded bootloader that allows them to be programmed via USART1 ?
2020-03-07 1:44 AM
Check AN2606 STM32 microcontroller system memory boot mode for your part number. Some of them do, some might not, some have it on another UART port. Watch out for the activation pattern.
