2018-04-26 03:39 AM
Hi am using STM32F107VCT6 and found there is no IR_OUT, IR_IN pins and the same I/O lines found in STM32F072VBT6. Please suggest how to use IR_OUT, IR_IN pins in STM32F107VCT6 or not. Thank you.
2018-04-26 10:04 AM
IR_OUT is just a NAND on two timer outputs, so you can replace it by an external NAND gate (e.g. a 74HC00, checking its current drive capability).
I don't know where do you see IR_IN.
