How to use FdCan with STM32L552RE ?
LDidi.1
I'm using Stm32Cubeide.
How to configure the parameter settings (Clock Divider, Frame Format,..) for a classic can 500K ?
Thanks for advance.
Imen.D
Hello @LDidi.1​ ,
You can use the example provided for the STM32L5 MCU with the FDCAN IP:
https://github.com/STMicroelectronics/STM32CubeL5/tree/master/Projects/STM32L552E-EV/Examples/FDCAN/FDCAN_Classic_Frame_Networking
or under this path STM32Cube_FW_L5_V1.4.0\Projects\STM32L552E-EV\Examples\FDCAN
You find a readme file describing how to test the application and you may update the example according to your needs.
Have a look also at this AN5348 Application note: FDCAN peripheral on STM32 devices.
Hope this helps you!
Imen
Imen
