How to setup USART to read unknown string lengths.
‎2020-05-26 2:42 PM
I'm using a NUCLEO-L053R8 board. I have tried a variety of USART settings including interrupt and DMA, but cannot reliably read unknown string lengths (at 115200 baud).
I want to read either until a certain character is seen, or for a specific period of time.
However, by using the Arduino IDE and running the NUCLEO as an Arduino, I have no problem using the 'serial.read()' function to accomplish the task.
What kind of magic is under the hood in the Arduino code?
STM32L0 Series
UART-USART
‎2020-05-26 3:03 PM
You can use HAL_UART_Receive() in a manner similar to serial.read. Adjust timeout and size to your use case:
uint8_t c = 0;
if (HAL_UART_Receive(&huart, &c, 1, 1000) == HAL_OK) {
// received character is in c
‎2020-05-26 10:09 PM
Try this one for starting point: https://github.com/MaJerle/stm32-usart-uart-dma-rx-tx
‎2020-05-27 5:44 AM
Thanks, but that method will loose characters at 115200 baud.
‎2020-05-27 7:52 AM
Looks like they use some smart heuristic to guess when to stop (timeout?) and their low level code is more efficient than the ST library.
-- pa
‎2020-05-28 6:34 AM
This is good information. Seems like my biggest issue was that the default clock frequency for an X-CUBE project on the NUCLEO-L053R8 board was 2MHz. Upping that to 30MHz solved the problem.
