shafeeshad
Visitor II
October 13, 2016
How to lock pin by GPIOx_LCKR register
  • October 13, 2016
  • 1 reply
  • 795 views
Posted on October 13, 2016 at 12:24
Hi everybody
I have read something about GPIOx_LCKR register in RM0008 page 173-174.
Those pages are about pin lock configuration in STM32f0xx.
As you know when we lock a pin, it's state should not be changed by configuring as high or low in pushpull. but my codes can't achieve that goal. Can you tell me what the problem is?
int main(void)
HAL_GPIO_LockPin(GPIOD,GPIO_PIN_7);
  while (1)
     HAL_GPIO_TogglePin(GPIOD,GPIO_PIN_7);
     HAL_Delay(200);
int main()
    uint32_t tmp = 0x00010000;
    tmp |= 0x00000080;
  // Set LCKK bit
  GPIOD->LCKR = tmp;
  // Reset LCKK bit
  GPIOD->LCKR = 0x00000080;
  // Set LCKK bit
  GPIOD->LCKR = tmp;
  // Read LCKK bit
  tmp = GPIOD->LCKR;
  // Read LCKK bit
  tmp = GPIOD->LCKR;
while(1)
      GPIOD->BSRR   &= ~0x00000080;
      GPIOD->BSRR   |=  0x00000080;
       delay(1000000);
      GPIOD->BSRR   &= ~0x00800000;
      GPIOD->BSRR   |=  0x00800000;
       delay(1000000);
at above codes LED PD.7 keeps blinking.
    1 reply
    Amel NASRI
    To give better visibility on the answered topics, please click on "Best Answer" on the reply which solved your issue or answered your question.
