How to import an Eclipse debug config (.launch) file?
Pavel A.
Evangelist III
When importing a .launch file in Atollic, the configuration is not imported. It deletes the .launch file and nothing becomes visible in debug settings.
The .launch file was created in the same Atollic IDE.
Atollic also does not detect .launch file if I copy it into the project directory.
Any idea how to do this?
-- pa
0 REPLIES 0
