How to generate SEV between cores in the STM32h745 / 747?
yuri CH
Hello!
Currently i am working with the STM32h745 dual core MCU, i am tring to create some
kind of synchonization between the m4 and the m7 cores.
for that i want to utilize the SEV. i already enabled the proper iterrupts in both cores.
my question is how to generate the interrupt from M7 to M4 or the other way? what is the code i have to write? (couldnt find any documantaion regarding this).
Please advise and thankis in advance.
This goes into some detail about it (the most I've seen anywhere):
https://www.st.com/resource/en/application_note/dm00771441-stm32h745755-and-stm32h747757-lines-interprocessor-communications-stmicroelectronics.pdf
__SEV will call the SEV assembly instruction to generate the interrupt.
Enable and implement the appropriate interrupt handlers (CM7_SEV_IRQHandler/CM4_SEV_IRQHandler) on each core.
There don't appear to be any usages of this in the CubeH7 repo:
https://github.com/search?q=CM4_SEV_IRQHandler+repo%3ASTMicroelectronics%2FSTM32CubeH7+extension%3Ac&type=Code
