mehmet.karakaya
how to configure EXTI ?
  • November 7, 2010
  • 4 replies
  • 669 views
Posted on November 07, 2010 at 01:26
    mehmet.karakaya
    Posted on May 17, 2011 at 14:14
    thank you I enabled AFIO clock and it worked
    in order not to open a new topic I have another question here
    I want a timer to tick between 1 Hz  and 10 KHz
    is there an example for this ? ( how to calculate prescaler and reload register for this job ? )
    Tesla DeLorean
    Guru
    May 17, 2011
    You must enable the AFIO clock, and the GPIOC clock.
    The EXTI registers are within the AFIO unit, chances are you haven't enabled it.
    Tesla DeLorean
    Guru
    May 17, 2011
    With SYSTICK. provided your main clock is within range.
    SysTick_Config(SystemCoreClock / 10); // 10 Hz
    SysTick_Config(SystemCoreClock / 10000); 10 KHz
      // TIM4CLK = 36 MHz
      x = 100; y = 36; // Clock at 1 MHz (36 MHz/36), 100 ticks, 10 KHz
    or
      x = 1000; y = 36000; // Clock at 1 KHz (36 MHz/36000), 1000 ticks, 1 Hz
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
      /* Time base configuration */
      TIM_TimeBaseStructure.TIM_Period = (x - 1); // 1-65536
      TIM_TimeBaseStructure.TIM_Prescaler = (y - 1); // 1-65536
      TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; // 1,2 or 4 for tDTS
      TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
    Tesla DeLorean
    Guru
    May 17, 2011
    I think I've posted examples before.
    The basic formula, f = CLK / (p * q), where Prescaler = (p - 1), Period = (q - 1), and where q = less than 65536
    I'll post some other examples in a bit.
