How to cancel transfer on OUT pipe of USB?
l-proger
Posted on August 10, 2015 at 10:14
Is there any way to cancel OUT transfer (receive) on STM32 using CubeF4 library?
I use USB in my device to communicate with PC (STM32 is ''device'', PC is ''host''). If client (PC side) program is ''crashed'' and my software protocol is not terminated correctly I have to send ''reset'' command to control (0) pipe of USB and handle it on STM32 side. The problem is that before the client application crashed last time, MCU firmware used USBD_LL_PrepareReceive function and device is waiting for data from PC!  I _have_ to cancel that transfer without resetting whole USB device stack. Is there any way to do that with CubeF4 library?
l-proger
Posted on August 10, 2015 at 13:00
OK, I got it   Edit: no, bad code!
PCD_HandleTypeDef *hpcd =hUsbDevice.pData;
USB_OTG_GlobalTypeDef *USBx = hpcd->Instance;
    USB_OTG_OUTEndpointTypeDef* outEp = GetOutEndpoint(&hUsbDevice, NDC_IF0_OUT_EP);
    USB_OTG_INEndpointTypeDef* inEp = GetInEndpoint(&hUsbDevice, NDC_IF0_IN_EP);
    //set global OUT NAK
    USBx->GINTMSK &= ~USB_OTG_GINTMSK_GONAKEFFM;
if((USBx->GINTSTS & USB_OTG_GINTMSK_GONAKEFFM) == 0){
USBx_DEVICE->DCTL |= USB_OTG_DCTL_SGONAK;
while((USBx->GINTSTS & USB_OTG_GINTMSK_GONAKEFFM) == 0){}
//begin disable EP
    USBx_DEVICE->DOEPMSK &= ~USB_OTG_DOEPMSK_EPDM; //Mask EP disabled interrupt for polling
outEp->DOEPCTL |= USB_OTG_DOEPCTL_SNAK | USB_OTG_DOEPCTL_EPDIS; //Begin disable
while((outEp->DOEPINT & USB_OTG_DOEPINT_EPDISD) == 0){} //Wait for disabled flag
outEp->DOEPINT = USB_OTG_DOEPINT_EPDISD; //Clear endpoint disabled interrupt
USBx_DEVICE->DOEPMSK |= USB_OTG_DOEPMSK_EPDM;//Unmask EP disabled interrupt
USBD_LL_FlushEP(&hUsbDevice, NDC_IF0_OUT_EP); //Flush EP FIFO
outEp->DOEPTSIZ = 0;
USBx_DEVICE->DCTL |= USB_OTG_DCTL_CGONAK; //Disable global OUT NAK
//Disable IN endpoint
//stop tramsmission
USBx_DEVICE->DIEPMSK &= ~USB_OTG_DIEPMSK_INEPNEM; //mask NAK effective interrupt
inEp->DIEPCTL |= USB_OTG_DIEPCTL_SNAK;
while((inEp->DIEPINT & USB_OTG_DIEPINT_INEPNE) == 0){} //wait 'till stopped
//disable endpoint
USBx_DEVICE->DIEPMSK &= ~USB_OTG_DIEPMSK_EPDM; //Mask EP disabled interrupt for polling
inEp->DIEPCTL |= USB_OTG_DIEPCTL_SNAK | USB_OTG_DIEPCTL_EPDIS; //begin disable
while((inEp->DIEPINT & USB_OTG_DIEPINT_EPDISD) == 0){}//wait for disable done
inEp->DIEPINT = USB_OTG_DIEPINT_EPDISD; //Clear endpoint disabled interrupt
USBx_DEVICE->DIEPMSK |= USB_OTG_DIEPMSK_EPDM; //unmask;
USBD_LL_FlushEP(&hUsbDevice, NDC_IF0_IN_EP);
inEp->DIEPTSIZ = 0;
//unmask NAK EFFECTIVE interrupt
USBx_DEVICE->DIEPMSK |= USB_OTG_DIEPMSK_INEPNEM;
inEp->DIEPCTL |= USB_OTG_DIEPCTL_CNAK;
while((inEp->DIEPCTL & USB_OTG_DIEPCTL_NAKSTS) != 0){}
inEp->DIEPINT = USB_OTG_DIEPINT_INEPNE; //Clear NAK effective interrupt
l-proger
Posted on September 23, 2015 at 16:45
Code in my previous post is not working good if DMA mode enabled in USB.
Here is correct version:
 portENTER_CRITICAL();
PCD_HandleTypeDef *hpcd = (PCD_HandleTypeDef *)hUsbDevice.pData;
USB_OTG_OUTEndpointTypeDef* outEp = USBx_OUTEP(hpcd->OUT_ep[NDC_IF0_OUT_EP & 0x7F].num);
USB_OTG_INEndpointTypeDef* inEp = USBx_INEP(hpcd->IN_ep[NDC_IF0_IN_EP & 0x7F].num);
//Disable OUT endpoint
if((outEp->DOEPCTL & USB_OTG_DOEPCTL_EPENA) == USB_OTG_DOEPCTL_EPENA){
//begin disable OUT EP
USBx->GINTMSK |= USB_OTG_GINTMSK_GONAKEFFM;
if ((inEp->DIEPCTL & USB_OTG_DIEPCTL_EPENA) == USB_OTG_DIEPCTL_EPENA){
inEp->DIEPCTL |= (USB_OTG_DIEPCTL_EPDIS | USB_OTG_DIEPCTL_SNAK);
inEp->DIEPTSIZ = 0;
//can clear custom software  RX/TX buffers here
portEXIT_CRITICAL();
l-proger
Posted on October 06, 2015 at 20:43
Update: small bugfixes in interrupts handling, now forking perfect in any tested conditions!
