2022-06-01 10:20 PM
2022-06-13 06:11 AM
Hi @Am.5 ,
I'll just assume you mean the CubeIDE.
It doesn't need to be added to the IDE, you just need to add it to the project. Why don't you just take a look how the cryptolib is used in other projects? For example the X-CUBE-SBSFU makes extensive use of the cryptolib.
BR,
J
