Hi, I have problems starting the program after a power reset. The program does not always start this way. Running through debag increases the startup percentage, but does not make it 100%. How can I fix it?
Options
‎2021-08-06 12:57 AM
Options
‎2021-08-06 1:03 AM
Make sure that the BOOT0 pin is pulled to ground ?
You should include more information in your question.
Options
‎2021-08-06 1:03 AM
Options
‎2021-08-06 1:41 AM
Thank you so much. I missed this moment(
