Hello, the STM32F030C8T6 chip I recently bought has repeatedly reset after the burning program, and can only be burned once. After the first successful burning, after the reset by external keys, the chip reset pin will continue to output triangle waves, r
ayang.11
您好,我最近买的STM32F030C8T6芯片在刻录程�?�?��??�?�?�?,�?�能烧录一次。第一次烧录�?功�?�,通过外键�?�?�?�,芯片�?�?引脚会继续输出三角波,导致芯片无法正常�?�动,无法�?次烧录。您�?�能在移除外部晶体振�?�器�?��?新连接STM32 ST-LINK实用程�?刻录工具进行下载和刻录。连续七个芯片都是如此。你之�?买的薯片烧完�?�就正常了。�?然间,这个问题无法解决。检查电路�?�接线�?�?�?电路和晶体振�?�器电路是�?��?�正常。MCU 内部硬件�?�?使能控制�?选项字节设置无效。编写空程�?也有�?�样的问题。拆下外部晶体振�?�器�?�,使用STM32 ST-LINK实用工具擦除整个芯片,芯片的�?�?�?�?消失,但晶体振�?�器�?振动。
FBL
Hello @ayang.1​,
Could you please reformulate your request in English to adhere to ST Community guidelines.
Best regards,
FBL
