Hello, can I use the external flash as a micro memory bank?؟؟ To do a firmware update
Hafsh.2
I want to update the firmware and my micro is a single bank flash memory.
 Is it possible to do a firmware update with this micro ??
 Or should it be dual bank flash memory ??
Can I use AT45DB321 as a second memory bank ??
Hafsh.2
Hello. Can anyone help me?
Piranha
Chief II
You haven't even mentioned the MCU...
Start with learning some basics:
https://stackoverflow.com/questions/34590379/how-to-implement-iap-in-application-programming-for-stm23f107-arm-microcontrol
After that continue to reading AN4657 as an example and AN2606.
Thanks for your tips
