2021-05-28 4:24 PM
This routeen fails on the line
Flash_End_Address() at flash_page.c:87 0x80004e6
where line 87 is
*DATA_64 = *(__IO uint64_t *)StartPageAddress;
_______________________________________________________________________________________
uint32_t Flash_End_Address (uint32_t StartPageAddress)
__IO uint64_t* DATA_64;
while (1){
if (*DATA_64 == 0xffffffffffffffff)
break;
StartPageAddress += 8;
return StartPageAddress;
This routeen works
uint32_t Flash_Read_Data (uint32_t StartPageAddress, __IO uint64_t * DATA_64)
while (1)
*DATA_64 = '\0';
break;
DATA_64++;
2021-05-28 7:04 PM
*DATA_64 = *(__IO uint64_t *)StartPageAddress;You're writing a value to the location of an uninitialized pointer. Seems like you want this instead:
__IO uint64_t DATA_64;
while (1)
if (DATA_64 == 0xffffffffffffffff)
break;
}or just:
while (1)
if (*(__IO uint64_t *)StartPageAddress == 0xffffffffffffffff)
break;
