Hardfault STM32
Options
2015-06-12 6:59 AM
Posted on June 12, 2015 at 15:59
1. I am using STM32 with keil v5.
2. In my code I am getting hardfault, however I don't see any error in ''fault report'' option of keil.3. What could be error?4. Attached is pic.http://www.docdroid.net/139z9/pic.pdf.html #wait-for-you--clive1-!-!-!
1 REPLY 1
Options
2015-06-12 7:06 AM
Posted on June 12, 2015 at 16:06
There are a lot of common errors that cause Hard Faults, I've covered these before. Most likely touching an illegal memory area. Suggest you start by getting a proper fault handler, see Joseph Yiu examples, and identify the instruction that is faulting, and the registers.
