2026-02-24 6:55 AM - last edited on 2026-02-24 8:09 AM by Andrew Neil
Heyho,
when enabling the INSTRUCTION cache in STM32H7(33), what must be taken care of?
Any cache handling required?
Any MPU settings required?
As far as I understood that's only required for DATA cache?
2026-02-24 7:26 AM
No special settings, you just need to enable it. (Unless you are modifying your instructions in code, which would be very atypical.)
2026-02-24 7:26 AM
