2010-12-01 5:27 AM
GPIO Port configuration register - max speed
2011-05-17 5:16 AM
Slew Rate control, slower rates will also reduce the overshoot and ringing, as the pins are driven less aggressively.
2011-05-17 5:16 AM
Lower electrical noise because of reduced slew rate helps analogue and also improves chances of passing EMC (radiated noise) tests.
2011-05-17 5:16 AM
''improves chances of passing EMC (radiated noise) tests.''
Also conducted noise?2011-05-17 5:16 AM
