FT5436 compatibility with FT5336 from STM32F746-DISCO
YTalh.1
I have made a custom board based on the STM32F746. I am using a touch panel which uses the FT5436. My question is: are the FT5336 drivers provided by with the STM32F746 discovery board drivers compatible with the FT5436? I cannot make it work. I cannot find any information about FT5436. Thank you!
5 REPLIES 5
support@focaltech-systems.com
What's the Part# of the PANEL you've selected?
YTalh.1
Thank you for your reply. I am using 4DLCD-70800480-CTP.
JLako.1
Hi, did you find the solution for FT5436 driver? If so, could you please share it?
YTalh.1
The FT5336 drivers are compatible with FT5436. It turned out that my issue was hardware related.
Good to know! Thank you for information.
