Freezing the IWGD Watchdog under Debug is not working
Timo Eggers
Posted on March 21, 2018 at 09:01
i have a STM32F051 and use the independent watchdog.
I would like the IWDG counter to stop if the core is halted.
I set the DBG_IWDG_STOP in the DBG Modul, but when i stop the core with the debuger my mcu still goes in reset.
I tried setting the bit with µVision IDE, with HAL driver code and with code writing to the register directly.
Best Regards,
Eggers
Timo Eggers
Posted on July 05, 2018 at 09:47
I found the problem!
You need to start the clock for the Debug Module!
You need to call __DBGMCU_CLK_ENABLE(); before calling __HAL_DBGMCU_FREEZE_IWDG();
1 REPLY 1
Timo Eggers
