Found startup_stm32f030x8.s BUG? TIM6 no interrupt.
‎2017-06-23 6:15 PM
I use STM32F030C8T6,found TIM6 no interrupt.
Check startup_stm32f030x8.s,there no TIM6_IRQHandler.
I add it,Is that correct?
‎2017-06-27 1:42 AM
Hello
H.Z.003
,You are using an old version of CubeF0and you should update the last version
STM32CubeF0 V
1.8.0 (the TIM6_IRQHandler is added in
since the version 1.7.0)Regards
Imen
Imen
‎2017-06-25 12:25 AM
‎2017-06-27 1:42 AM
Hello
H.Z.003
STM32CubeF0 V
Imen
Imen
