Flash memory write -> HardFault_Handler
‎2014-04-12 08:43 AM
Hi everyone,
I have problem with writing to flash memory in my application. uC STM32F051C4Code:#define FLASH1 (*((uint32_t *)0x08001016))then flash function:void FLASHunlock(void){ if (FLASH->CR &0x00000080) { FLASH->KEYR = 0x45670123; FLASH->KEYR = 0xCDEF89AB; }}void FLASHwrite(void){ uint16_t z=0xF0F0; FLASHunlock(); while(FLASH->SR & 0x00000001); FLASH->CR = 0x00000001; FLASH1 = z; -> here program jumps to HardFault_Handler while (FLASH->SR & 0x00000001);}Any ideas? Flash is eriassed (everywhere FF FF)- Mark as New
‎2014-04-12 05:23 PM
Use a WORD aligned address
‎2014-04-13 01:45 AM
How? :)
‎2014-04-13 02:19 AM
How? :)
Use an address which is divisible by FOUR #define FLASH1 (*((uint32_t *)0x08001018)) I have other issues with your code, but that's why it's faulting.Up vote any posts that you find helpful, it shows what's working..
‎2014-04-13 02:58 AM
I still get HardFault_Handler with 0x08001018,
I was checking elier with 08004000, 08002000 - same story. Please share other issues :)Experiment:When i change adress to 0x48000014 witch is GPIOA ODR, everything works.Data is stored on LSB bits of GPIOA, register value is 0x0000F0F0- Mark as New
‎2014-04-13 06:22 AM
‎2014-04-13 11:09 AM
The ST library code sets/clears the PG bit without disturbing the other bits, looks at the SR slightly differently, and has some additional latency based on the subroutine calls.
