2013-03-27 02:59 AM
I did not receive response for my previous question;
Here is the exact description of the problem. Command below c:\''Program files\STMicroelectronics\Software\Flash Loader Demonstrator''\STMFlashLoader.exe -? returns bad parameter [files\STMicroelectronics\Software\Flash] message. This is bag. The version 2.4.0 works correctly. To the STMicroelectronics software designers. This is obviously bag in the STMFlashLoader.exe command line parser. Please, check and correct the problem.2013-03-27 03:46 AM
Have you tried with quotes around the whole file path i.e.
''c:\Program files\STMicroelectronics\Software\Flash Loader Demonstrator\STMFlashLoader.exe'' -?2013-03-27 04:07 AM
Thank you very much!
It works.
