zamolan
Exclamation mark breakpoint
  • November 26, 2014
  • 1 reply
  • 1127 views
Posted on November 26, 2014 at 18:20
 Hi!
Keil  MDK Lite V5.12
 I cannot tell why the debugger cannot breakpoint certain rows. Like a CAN_Transmit function. Not only will put an exclamation mark, it will jump over it completely. This function is that time-sensitive that you cannot break it?
Nor breakpoints inside the function will be called. The code just simply jumps over that part. Why? I can link the code, if needed, though I doubt the ''problem'' is a particular one. Rather my lack of knowledge.
Thank you!
#exclamation #breakpoint
    1 reply
    Tesla DeLorean
    Guru
    November 26, 2014
    Posted on November 26, 2014 at 19:04
    Turn off optimization, that way there will be a more simplistic one-to-one linear code flow.
