Error instantiating RTE components
Error #542: API '::Board Support.LED:1.0.0(API)' required by component 'Keil.STM32F4-Discovery::Board Support:LED:2.0.0' is missing
‎2018-08-24 1:45 PM
I'm using Windows 10 and arm KEIL IDE along with STM32F407G-DISCOVERY board. I'm a very beginner and trying to do something with LED. I'm stuck at the initial stage itself.
I have a problem with the LED API in the Board Support Package in the setup process. I tried to install two different DFPs using the Pack Installer ( latest version: 2.13.0 and little older version 2.11.0). But with both of them I see errors. Can someone please help
‎2018-08-24 2:35 PM
What happens if you click the Resolve button?
-- pa
‎2018-08-24 3:17 PM
Thanks for the response. It doesn't do anything just simply remains as it is. At other other places while I was doing setup process when there was Yellow colored check mark and when I clicked on Resolve, it then fixed the problem automatically but here it's RED colored warning maybe something more intense so it cannot resolve automatically on it's own
‎2018-08-25 5:41 AM
Maybe Keil support can help you to find the needed pack.
-- pa
