Encoder modes
schauhan11
Posted on December 06, 2008 at 04:07
Encoder modes
3 REPLIES 3
schauhan11
Posted on May 17, 2011 at 12:55
I am starting a new motor control design that needs to read an encoder in full quadrature mode (4X mode, where count changes on both transitions of channel A and B).
I would like to know if this is possible and if there is example code (preferably in C) that shows how to configure the timer and read the count. It would be great to have more encoder related functions added to future version of firmware library.
Sam
jaroslaw2
There is info you are looking for
http://www.st.com/mcu/forums-cat-7460-23.html
schauhan11
Thanks for the reply. However, discussion in that thread is hard to follow. I would like to see a simple example of how to set up advanced timer for quadrature encoder mode and then use it to keep track of a 32 bit counter.
Sam
