eeprom write page error
er3481
I am trying to write some datato external eeprom with I2C_EEPROM_WritePage function, but it doesn't write everytime. Sometimes it can write and sometimes it can't. I am using standart peripheral I2C library and using the write page function below. Any advise ?
void I2C_EEPROM_WritePage(unsigned char* pBuffer, unsigned short MemAddr, unsigned short NumData, unsigned char mode)
  unsigned char byteRemain;
  if(I2C_EE_State & I2C_STATE_ERROR)
    I2C_EEPROM_ErrorCallback();
  if((NumData == 0) || ((MemAddr+ NumData) > (I2C_DRIVER_MAX_SUPPORTED_SIZE - 1)))
    return; /* nothing to write or not allowed */
  while(NumData > 0)
    /* calculate remaining bytes till page end */
    byteRemain = I2C_currentSettings->EE_pageSize - ((unsigned short)MemAddr % I2C_currentSettings->EE_pageSize);
    /* bytes fit in page */
    if(byteRemain >= NumData)
      if(I2C_EEPROM_Write(pBuffer, MemAddr, NumData, mode) == I2C_ERROR)
      // write error
        WDG_RESET();
      NumData = 0;
    /* bytes overlap with next page */
    else
      /* write bytes into page till page end */
      if(I2C_EEPROM_Write(pBuffer, MemAddr, byteRemain, mode) == I2C_ERROR)
      // write error
      NumData -= byteRemain;
      MemAddr += byteRemain;
      if(mode == I2C_MODE_NORMAL)
          pBuffer += byteRemain;
  return;
I2C_eResult I2C_EEPROM_Write(unsigned char *pBuffer, unsigned short MemAddr, unsigned short NumData, unsigned char mode)
  /* check I2C Driver state */
  if((I2C_EE_State & I2C_STATE_READY) && !(I2C_EE_State & I2C_STATE_ERROR))
    if(NumData == 0)
      return I2C_DENIED; /* nothing to read */
    else
      /* update state machine */
      I2C_EE_State |= I2C_STATE_BUSY;
      I2C_EE_State &= ~I2C_STATE_READY;
    /* generate start condition TX */
    if(I2C_EEPROM_Start(I2C_Direction_Transmitter) == I2C_ERROR)
        return I2C_ERROR; /* communication error */
    I2C_EEPROM_SendAddr(MemAddr);  /* send 16 bit address */
    while(NumData > 0)
      I2C_SendMasterByte(*pBuffer);
      NumData--;
          pBuffer++;
    /* wait until byte transmitted */
    I2C_EE_Timeout = I2C_currentSettings->I2C_timeoutWr + 1; // +1 with I2C_timeoutWr = 1 allows
    // that for sending timer interrupt can occure at least once
    while(!I2C_CheckEvent(I2C_DEV_EEPROM, I2C_EVENT_MASTER_BYTE_TRANSMITTED) && I2C_EE_Timeout > 0)
    /* Send STOP Condition */
    I2C_GenerateSTOP(I2C_DEV_EEPROM, ENABLE);
    /* Wait to make sure that STOP control bit has been cleared */
    I2C_EE_Timeout = I2C_currentSettings->I2C_timeoutDefault;
    while((I2C_ReadRegister(I2C_DEV_EEPROM, I2C_Register_CR1)) & I2C_CR1_STOP)
      if(I2C_EE_Timeout == 0)
        I2C_EE_State |= I2C_STATE_ERROR | I2C_ERR_TX;
        return I2C_ERROR;
    // reset write control
    I2C_EEPROM_WriteControl(DISABLE);
    I2C_EE_State |= I2C_STATE_READY;
    I2C_EE_State &= ~I2C_STATE_BUSY;
    return I2C_SUCCESS;
  else
    /* driver not ready */
    I2C_EE_State |= I2C_STATE_ERROR;
    return I2C_ERROR;
0 REPLIES 0
