Does CubeMX take care of hardware errors? (erratas)
gvuyk07
Posted on March 21, 2016 at 21:27
Does CubeMx implement the workarounds described on the erratas file or that is the user's job?
Posted on March 22, 2016 at 00:20
Well perhaps some of them. Usually protects you from the hazards related to the AHB/APB clock enables, and TIM->SR flag clearing etc.
Probably less so the Cortex's tail chaining pipeline hazard.
I'd recommend you keep the errata in mind as you code your solution. Cube is just a frame-work creator, assuming it is much else is perhaps dangerous.
stm32cube-t
Posted on October 07, 2016 at 12:12
Dear user,
it is part of our process now. Starting with STM32CubeMX 4.17 (coming out soon), STM32CubeMX shall reveal MCUs limitations as listed in the errata sheet.
Best regards
