DfuSe demonstration tool - exist a command line version?
Posted on January 27, 2011 at 10:58
cpryor
Posted on May 17, 2011 at 14:23
Hallo,
I'm searching for a solution too.
chikos332
Hi Sebastian,
Are you interested of having a command line option for programming through USART (RS232 serial interface)?
This option exists in ST Flash loader demonstrator tool.
For the DFUse, you have to know that you need specific USB driver to control DFU protocol...as far as I know there is no command line interface for this driver provided by ST.
Cheers.
Chikos.
stforum.tormod9
Did anyone try to compile the dfuse-dfu-util under Windows? Should work since the original dfu-util code has Windows specific tweaks.
Otherwise, I just discovered an alternative, written in python, from here:
http://www.fsij.org/gnuk/version0_4
EDIT: dfu-util windows binaries
https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/DispForm.aspx?ID=22532
