FAlbe
Visitor II
June 18, 2019
DFU file from command prom
  • June 18, 2019
  • 1 reply
  • 725 views
Hi
I would like to create the DFU file once I compile the whole program, in a way the the file *.dfu is already ready to be updated with the bootloader.
I already know that there is the program "Dfu file manager", does anyone know how to use it from command prompt in a way that I can do a script file to execute the conversion directly without opening it?
Does anyone can give me an hint?
Thank you in advance
1 reply
Tesla DeLorean
Guru
June 18, 2019
I posted a HEX2DFU utility some time ago
