Decoding bmp ?
‎2014-04-11 2:21 AM
Guys,
Does anyone of you have experience on decoding bmp ? I want to display bmp file to my LCD... Any clues ? thanks #i-have-a-clue- Mark as New
‎2014-04-28 5:13 PM
Pretty sure the printf() there isn't appropriate.
Yes, start by filling the panel with colour, and confirm those actually work, or if the colour is wrong.Up vote any posts that you find helpful, it shows what's working..
‎2014-04-28 5:17 PM
Can you display white properly in your LCD ?
I will check tomorrow, but pretty sure it does.Up vote any posts that you find helpful, it shows what's working..
‎2014-04-28 6:03 PM
The SSD1289 has a Transparency bit in Register 0x11, but it's application with respect to the data stream is not discussed further.
You could presumably do a testif (rgb == 0xFFFF) rgb = 0xFFFE;Up vote any posts that you find helpful, it shows what's working..
‎2014-04-28 11:43 PM
Like this :
if (rgb == 0xFFFF) rgb = 0xFFFE; rgb = ((rgb & 0xF80000) >> 8) | ((rgb & 0x00FC00) >> 5) | ((rgb & 0x0000F8) >> 3); LCD_SetPoint(y/3, x/3, rgb); I got no response, still dot dot white on the screen...- Mark as New
‎2014-04-29 12:18 AM
No like this, do you have no sense of logic and sequence?
rgb = ((rgb & 0xF80000) >> 8) | ((rgb & 0x00FC00) >> 5) | ((rgb & 0x0000F8) >> 3); // convert to colour space of display
if (rgb == 0xFFFF) rgb = 0xFFFE; // address transparent/white issue
LCD_SetPoint(y/3, x/3, rgb); // paint dot on screen
‎2014-04-29 12:52 AM
it's changing to FFFE but not in a solid LCD, there are some black spots on LCD...why is it ?
‎2014-04-29 12:55 AM
‎2014-04-29 12:57 AM
or
if (rgb == 0xFFFF) rgb = 0xFFFD; works allright..- Mark as New
‎2014-04-29 12:07 PM
You are asking me questions about a board and screen that I don't have, and cannot independently verify/test.
It is possible that x/3 or y/3 exceed the dimensions of the display.Up vote any posts that you find helpful, it shows what's working..
‎2014-04-29 2:08 PM
The SSD1298 on the STM32F407 does appear to display the primary colours properly, and doesn't have issues with transparent/clear 0xFFFF. Painted the Blue/White flag without issue.
