Decoding bmp ?
‎2014-04-11 2:21 AM
Guys,
Does anyone of you have experience on decoding bmp ? I want to display bmp file to my LCD... Any clues ? thanks #i-have-a-clue- Mark as New
‎2014-04-18 5:06 AM
Ok, I have the manual for the SSD part, do you have any manual/documentation/schematics for the BOARD you are using?
Can you see and image of the flowers, but with the wrong colours? I can't make out anything through the flash glare. Perhaps you have some #defines for RED, GREEN or BLUE colours passed to the functions you are using? Or a cite to the library/code?Up vote any posts that you find helpful, it shows what's working..
‎2014-04-18 5:21 AM
Yes I can see flower but the color is not right,
Yes I have define : #define Blue 0x001F #define Red 0xF800 #define Green 0x07E0 I attached the schematic, please check it out, thanks ________________ Attachments : schematic_stm32.jpg : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1I8&d=%2Fa%2F0X0000000bkr%2Fdneyq8Z1q_k5BZnBTOBusZpTZSKu41Lfl2osoufSjeA&asPdf=false- Mark as New
‎2014-04-18 6:08 AM
// RRRRRRRRGGGGGGGGBBBBBBBB 8:8:8
// RRRRRGGGGGGBBBBB 5:6:5
pal = ((pal & 0xF80000) >> 8) | ((pal & 0x00FC00) >> 5) | ((pal & 0x0000F8) >> 3);
‎2014-04-18 6:24 AM
Thanks for the info,
May I know how can you get those values ?- Mark as New
‎2014-04-18 6:26 AM
I tested and it gave me the same result, only the color was changing to blueish...
do I miss something here ?- Mark as New
‎2014-04-18 6:54 AM
I'm attempting to translate the colour space formats.Up vote any posts that you find helpful, it shows what's working..
‎2014-04-18 2:21 PM
From my SSD1298 panel
‎2014-04-18 3:59 PM
I'm using SSD1289, is it the same with SSD1298 ?
Here's the complete function I used
void LCD_DrawBMPFromFile()
char temp_buffer[100],line[512];
int count,z,bmpData,bmpAddr;
int x = 0;
int i,y = 0;
int xx, yy;
uint8_t hdr[0x28];
UINT bytesread;
uint8_t hdr_256[0x36];
static uint16_t w[256];
uint32_t off;
uint16_t icon[300] =
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
printf(''LCD_DrawBMPFromFile Function....
LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
// LCD_Clear(Black);
//res = f_open( &fsrc , ''test.bmp'' , FA_READ );
res = f_open( &fsrc , ''Demo.TXT'' , FA_READ);
printf(''res value = '');
sprintf(temp_buffer,''%.2d'',res);printf(temp_buffer);printf(''
printf(''Content of the file :'');
NEXT_LINE;
while (f_gets(line, sizeof line, &fsrc))
printf(line);
f_close(&fsrc);
//display welcome to LCD
delay_init();
//LCD_Initializtion();
//write LCD RAM here
//LCD_SetCursor(239,0);
//LCD_DrawPicture(0,0,239,319,icon);
// int i, x, y;
//LCD_SetCursor(0,0);
res = f_open(&fsrc, ''test1.bmp'', FA_READ);
//f_seek(&fsrc, 0x3E, F_SEEK_SET); // Seek to the data
f_lseek(&fsrc, 0x3E);
for(y=1; y<
240
; y++)
for(
x
1
; x<320; x+=8) // advance 8 pixels (one byte of bits)
uint8_t b;
//UINT bytesread;
f_read(&fsrc, &b, 1, &bytesread); // Read byte
for(
i
0
; i<8; i++) // Process bits in byte, MSB first
if (b & 0x80) // Pixel On?
//LCD_SetPoint(x+i, y, 0xF0F0); // Colour
LCD_SetPoint(y, x+i, 0xF0F0); // Colour
else
//LCD_SetPoint(x+i, y, 0x0000); // Black
LCD_SetPoint(y, x+i, 0x0000); // Black
b <<= 1;
} // x
} // y
f_close(&fsrc);
//second picture
delay_ms(1500);
res
f_open
(&fsrc, ''test2.bmp'', FA_READ);
for(
y
1
; y<240; y++)
for(
x
1
uint8_t b;
//UINT bytesread;
for(
i
0
else
b <<= 1;
} // x
} // y
f_close(&fsrc);
delay_ms(1500);
//test3 bmp
res
f_open
(&fsrc, ''button1.bmp'', FA_READ);
f_read(&fsrc, hdr, sizeof(hdr), &bytesread); // Read header
xx = *((uint32_t *)&hdr[0x12]); // X pixels (want multiple of 8)
yy = *((uint32_t *)&hdr[0x16]); // Y pixels
f_lseek(&fsrc, 0x3E); // Seek to the data
for(
y
0
; y<yy; y++)
for(
x
0
; x<xx; x+=8) // advance 8 pixels (one byte of bits)
uint8_t b;
//UINT bytesread;
for(
i
0
//LCD_SetPoint(y,x+i, b); // Colour
LCD_SetPoint(y,x+i, 0xF0F0); // Colour
else
LCD_SetPoint(y,x+i, 0x0000); // Black
b <<= 1;
} // x
} // y
f_close(&fsrc);
delay_ms(1500);
//256 color bmp
res
f_open
(&fsrc, ''test8.bmp'', FA_READ);
f_read(&fsrc, hdr_256, sizeof(hdr), &bytesread); // Read header
off = *((uint32_t *)&hdr_256[0x0A]); // offset to rasters
xx = *((uint32_t *)&hdr_256[0x12]); // X pixels
yy = *((uint32_t *)&hdr_256[0x16]); // Y pixels
for(
i
0
; i<256; i++) // Build palette conversion (+0x46 count?)
uint32_t pal;
f_read(&fsrc, &pal, 4, &bytesread); // Read palette B G R
// BBBBBGGGGGGRRRRR 5:6:5
//pal = ((pal & 0x00FC00) >> 5) | ((pal & 0xF80000) >> 19) | ((pal & 0x0000F8) <<
8
//pal = ((pal & 0x001F00) >> 5) | ((pal & 0x7E0000) >> 19) | ((pal & 0x0000F8) << 8);
w[i] = (uint16_t)pal;
f_lseek(&fsrc, off); // Seek to the data
for(y=0; y<yy; y++)
for(x=0; x<xx; x++)
uint8_t b;
LCD_SetPoint(y, x, w[b]); // Colour Map
} // x
} // y
f_close(&fsrc);
delay_ms(5000);
‎2014-04-18 4:09 PM
if(DeviceCode==0x8989)
LCD_WriteReg(0x0000,0x0001); LCD_Delay(5); /* ´ò¿ª¾§Õñ */
LCD_WriteReg(0x0003,0xA8A4); LCD_Delay(5);
LCD_WriteReg(0x000C,0x0000); LCD_Delay(5);
LCD_WriteReg(0x000D,0x080C); LCD_Delay(5);
LCD_WriteReg(0x000E,0x2B00); LCD_Delay(5);
LCD_WriteReg(0x001E,0x00B0); LCD_Delay(5);
LCD_WriteReg(0x0001,0x2B3F); LCD_Delay(5); /* Çý¶¯Êä³ö¿ØÖÆ320*240 0x2B3F */
LCD_WriteReg(0x0002,0x0600); LCD_Delay(5);
LCD_WriteReg(0x0010,0x0000); LCD_Delay(5);
LCD_WriteReg(0x0011,0x6070); LCD_Delay(5); /* ¶¨ÒåÊý¾�?¸ñʽ 16λɫ ºáÆ�? 0x6070 */
//LCD_WriteReg(0x0011,0x4070); LCD_Delay(5); /* ¶¨ÒåÊý¾�?¸ñʽ 16λɫ ºáÆ�? 0x6070 262K page 41 SSD1289 datasheet */
LCD_WriteReg(0x0005,0x0000); LCD_Delay(5);
LCD_WriteReg(0x0006,0x0000); LCD_Delay(5);
LCD_WriteReg(0x0016,0xEF1C); LCD_Delay(5);
LCD_WriteReg(0x0017,0x0003); LCD_Delay(5);
LCD_WriteReg(0x0007,0x0133); LCD_Delay(5);
LCD_WriteReg(0x000B,0x0000); LCD_Delay(5);
LCD_WriteReg(0x000F,0x0000); LCD_Delay(5); /* ɨÃ迪ʼµØÖ· */
LCD_WriteReg(0x0041,0x0000); LCD_Delay(5);
LCD_WriteReg(0x0042,0x0000); LCD_Delay(5);
LCD_WriteReg(0x0048,0x0000); LCD_Delay(5);
LCD_WriteReg(0x0049,0x013F); LCD_Delay(5);
LCD_WriteReg(0x004A,0x0000); LCD_Delay(5);
LCD_WriteReg(0x004B,0x0000); LCD_Delay(5);
LCD_WriteReg(0x0044,0xEF00); LCD_Delay(5);
LCD_WriteReg(0x0045,0x0000); LCD_Delay(5);
LCD_WriteReg(0x0046,0x013F); LCD_Delay(5);
LCD_WriteReg(0x0030,0x0707); LCD_Delay(5);
LCD_WriteReg(0x0031,0x0204); LCD_Delay(5);
LCD_WriteReg(0x0032,0x0204); LCD_Delay(5);
LCD_WriteReg(0x0033,0x0502); LCD_Delay(5);
LCD_WriteReg(0x0034,0x0507); LCD_Delay(5);
LCD_WriteReg(0x0035,0x0204); LCD_Delay(5);
LCD_WriteReg(0x0036,0x0204); LCD_Delay(5);
LCD_WriteReg(0x0037,0x0502); LCD_Delay(5);
LCD_WriteReg(0x003A,0x0302); LCD_Delay(5);
LCD_WriteReg(0x003B,0x0302); LCD_Delay(5);
LCD_WriteReg(0x0023,0x0000); LCD_Delay(5);
LCD_WriteReg(0x0024,0x0000); LCD_Delay(5);
LCD_WriteReg(0x0025,0x8000); LCD_Delay(5);
LCD_WriteReg(0x004f,0); /* �?�?Ê×Ö·0 */
LCD_WriteReg(0x004e,0); /* �?�?Ê×Ö·0 */
My LCD initialization code, is it the same with SSD1298 ? may I see it please ? thanks
‎2014-04-18 5:05 PM
void lcd_init(void)
port_fsmc_init();
//GPIO_ResetBits(GPIOD,GPIO_Pin_3);
//delay(500);
//GPIO_SetBits(GPIOD,GPIO_Pin_3);
//delay(50);
GPIO_SetBits(GPIOF,GPIO_Pin_9);
delay(100);
DeviceCode = read_reg(0x0000);
DeviceCode = 0x8999;
if (DeviceCode == 0x8999)
// power supply setting
// set R07h at 0021h (GON=1,DTE=0,D[1:0]=01)
write_reg(0x07,0x0021);
// set R00h at 0001h (OSCEN=1)
write_reg(0x00,0x0001);
// set R07h at 0023h (GON=1,DTE=0,D[1:0]=11)
write_reg(0x07,0x0023);
// set R10h at 0000h (Exit sleep mode)
write_reg(0x10,0x0000);
// Wait 30ms
delay(3000);
// set R07h at 0033h (GON=1,DTE=1,D[1:0]=11)
write_reg(0x07,0x0033);
// Entry mode setting (R11h)
// R11H Entry mode
// vsmode DFM1 DFM0 TRANS OEDef WMode DMode1 DMode0 TY1 TY0 ID1 ID0 AM LG2 LG2 LG0
// 0 1 1 0 0 0 0 0 0 1 1 1 * 0 0 0
write_reg(0x11,0x6070);
// LCD driver AC setting (R02h)
write_reg(0x02,0x0600);
// power control 1
// DCT3 DCT2 DCT1 DCT0 BT2 BT1 BT0 0 DC3 DC2 DC1 DC0 AP2 AP1 AP0 0
// 1 0 1 0 1 0 0 0 1 0 1 0 0 1 0 0
// DCT[3:0] fosc/4 BT[2:0] DC{3:0] fosc/4
write_reg(0x03,0x0804);//0xA8A4
write_reg(0x0C,0x0000);//
write_reg(0x0D,0x080C);//
// power control 4
// 0 0 VCOMG VDV4 VDV3 VDV2 VDV1 VDV0 0 0 0 0 0 0 0 0
// 0 0 1 0 1 0 1 1 0 0 0 0 0 0 0 0
write_reg(0x0E,0x2900);
write_reg(0x1E,0x00B8);
write_reg(0x01,0x2B3F);//Çý¶¯Êä³ö¿ØÖÆ320*240 0x6B3F
write_reg(0x05,0x0000);
write_reg(0x06,0x0000);
write_reg(0x16,0xEF1C);
write_reg(0x17,0x0003);
write_reg(0x07,0x0233);//0x0233
write_reg(0x0B,0x0000|(3<<6));
write_reg(0x0F,0x0000);//ɨÃ迪ʼµØÖ·
write_reg(0x41,0x0000);
write_reg(0x42,0x0000);
write_reg(0x48,0x0000);
write_reg(0x49,0x013F);
write_reg(0x4A,0x0000);
write_reg(0x4B,0x0000);
write_reg(0x44,0xEF00);
write_reg(0x45,0x0000);
write_reg(0x46,0x013F);
write_reg(0x30,0x0707);
write_reg(0x31,0x0204);
write_reg(0x32,0x0204);
write_reg(0x33,0x0502);
write_reg(0x34,0x0507);
write_reg(0x35,0x0204);
write_reg(0x36,0x0204);
write_reg(0x37,0x0502);
write_reg(0x3A,0x0302);
write_reg(0x3B,0x0302);
write_reg(0x23,0x0000);
write_reg(0x24,0x0000);
write_reg(0x25,0x8000); // 65hz
write_reg(0x4f,0); // �?�?Ê×Ö·0
write_reg(0x4e,0); // �?�?Ê×Ö·0
else
//printf(''LCD model is not recognized,DeviceCode = 0x%x!
'',DeviceCode);
//return;
//Êý¾�?×Ü�?ß²âÊÔ,ÓÃÓÚ²âÊÔÓ²¼þ�?¬½ÓÊÇ·ñÕý³£.
lcd_data_bus_test();
lcd_clear(Red);
