2011-08-01 05:00 AM
hello,
i m using IAR kickstart version for code limit of 32k and when i run my example code available on st website for LCD display application, i get an declaration error as :-
Error[Pe147]: declaration is incompatible with ''__interwork __softfp unsigned long __REV16(unsigned long)'' (declared at D:\atul\IAR\LCD\STM32F10x_AN2790_FW_V2.0.0\Libraries\CMSIS\Core\CM3\core_cm3.h 689
pls help me if any one can..........
#declaration-error #stm322011-08-01 10:28 AM
http://supp.iar.com/Support/?note=75890&from=search+result
2011-08-02 04:38 AM
which version IAR are you using?? 6.2??
if yes once try this following step. copy the attached file atC:\Program Files\IAR Systems\Embedded Workbench 6.2\arm\inc\c
________________ Attachments : intrinsics.h : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1ID&d=%2Fa%2F0X0000000bkw%2F8um80xKNrRN3hq85BLfYJRwv5yyASrlcPzjoPtzZ594&asPdf=false
