Vel
Data Splitting??
  • September 18, 2019
  • 0 replies
  • 488 views
I am using stm32h753, in my design. I am using SAI Peripheral for audio(TAS2770 Ic) with internal synchronization method. In receiving mode ,my configuration of slot is slot 0 | slot1.
In transmitting mode, configuration of slot is SAI_SLOTACTIVE_0 | SAI_SLOTACTIVE_2 |SAI_SLOTACTIVE_3.
While receiving data, i got multiple datas in that array using HAL_SAI_Receive_DMA library function. i am expecting the current and voltage value from audio device. but how to separate the voltage and current value??
SAI configuration:-
   hsai_BlockA1.Instance            =      SAI1_Block_A;
   hsai_BlockA1.Init.Protocol         =      SAI_FREE_PROTOCOL;
   hsai_BlockA1.Init.MckOutput         =      SAI_MCK_OUTPUT_DISABLE;
   hsai_BlockA1.Init.AudioMode      =      SAI_MODEMASTER_TX;
   hsai_BlockA1.Init.Synchro         =      SAI_ASYNCHRONOUS;
   hsai_BlockA1.Init.MonoStereoMode   =      SAI_MONOMODE;
   hsai_BlockA1.Init.OutputDrive      =      SAI_OUTPUTDRIVE_DISABLE;
   hsai_BlockA1.Init.NoDivider      =      SAI_MASTERDIVIDER_DISABLE;
   hsai_BlockA1.Init.MckOverSampling   =      SAI_MCK_OVERSAMPLING_ENABLE;
   hsai_BlockA1.Init.Mckdiv         =      13;//26
   hsai_BlockA1.Init.FIFOThreshold   =      SAI_FIFOTHRESHOLD_FULL;
   hsai_BlockA1.Init.AudioFrequency   =      SAI_AUDIO_FREQUENCY_96K;
   hsai_BlockA1.Init.DataSize         =      SAI_DATASIZE_16;
   hsai_BlockA1.Init.FirstBit         =      SAI_FIRSTBIT_MSB;
   hsai_BlockA1.Init.ClockStrobing   =      SAI_CLOCKSTROBING_RISINGEDGE;
   hsai_BlockA1.Init.CompandingMode   =      SAI_NOCOMPANDING;
   hsai_BlockA1.FrameInit.FrameLength         =   32;
   hsai_BlockA1.FrameInit.ActiveFrameLength   =   16;
   hsai_BlockA1.FrameInit.FSDefinition      =   SAI_FS_STARTFRAME;
   hsai_BlockA1.FrameInit.FSPolarity         =   SAI_FS_ACTIVE_LOW;
   hsai_BlockA1.FrameInit.FSOffset         =   SAI_FS_FIRSTBIT;
   hsai_BlockA1.SlotInit.FirstBitOffset      =   1;
   hsai_BlockA1.SlotInit.SlotSize            =   SAI_SLOTSIZE_DATASIZE;
   hsai_BlockA1.SlotInit.SlotNumber         =   4;
   hsai_BlockA1.SlotInit.SlotActive         =   (SAI_SLOTACTIVE_0|SAI_SLOTACTIVE_2|SAI_SLOTACTIVE_3);
   if (HAL_SAI_Init(&hsai_BlockA1) != HAL_OK)
   //      Error_Handler();
   hsai_BlockB1.Instance            =      SAI1_Block_B;
   hsai_BlockB1.Init.Protocol         =      SAI_FREE_PROTOCOL;
   hsai_BlockB1.Init.MckOutput         =      SAI_MCK_OUTPUT_DISABLE;
   hsai_BlockB1.Init.AudioMode      =      SAI_MODESLAVE_RX;
   hsai_BlockB1.Init.Synchro         =      SAI_SYNCHRONOUS;
   hsai_BlockB1.Init.MonoStereoMode   =      SAI_MONOMODE;
   hsai_BlockB1.Init.OutputDrive      =      SAI_OUTPUTDRIVE_DISABLE;
   hsai_BlockB1.Init.NoDivider      =      SAI_MASTERDIVIDER_DISABLE;
   hsai_BlockB1.Init.FIFOThreshold   =      SAI_FIFOTHRESHOLD_EMPTY;
   hsai_BlockB1.Init.DataSize         =      SAI_DATASIZE_8;
   hsai_BlockB1.Init.FirstBit         =      SAI_FIRSTBIT_MSB;
   hsai_BlockB1.Init.ClockStrobing   =      SAI_CLOCKSTROBING_FALLINGEDGE;
   hsai_BlockB1.Init.CompandingMode   =      SAI_NOCOMPANDING;
   hsai_BlockB1.FrameInit.FrameLength         =   32;
   hsai_BlockB1.FrameInit.ActiveFrameLength   =   8;
   hsai_BlockB1.FrameInit.FSDefinition      =   SAI_FS_STARTFRAME;
   hsai_BlockB1.FrameInit.FSPolarity         =   SAI_FS_ACTIVE_LOW;
   hsai_BlockB1.FrameInit.FSOffset         =   SAI_FS_FIRSTBIT;
   hsai_BlockB1.SlotInit.FirstBitOffset      =   1;
   hsai_BlockB1.SlotInit.SlotSize            =   SAI_SLOTSIZE_DATASIZE;
   hsai_BlockB1.SlotInit.SlotNumber         =   4;
   hsai_BlockB1.SlotInit.SlotActive         =   SAI_SLOTACTIVE_0 | SAI_SLOTACTIVE_1;
   if (HAL_SAI_Init(&hsai_BlockB1) != HAL_OK)
//      Error_Handler();
Thanks.,
vel
